Old 03-23-2018, 03:50 PM   #332 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
A little disappointing
Originally Posted by iikhod View Post
Looking good. Like you said, it is different. I myself would paint the whole "edge" of the rim.
I had thought about doing the edge in black and let the green 1/4" pin stripe sit on that. But that's a color scheme everyone does... A stripe on black. I wanna explore a little.
Speaking of exploring, the plastidip on the hole fillings is not working so great. Here are three: far right is unpainted weed block on the foil tape, middle is one coat plasti done in place (resulting in bad overspray partly cleaned-up), and third from right is FOUR coats of plasti after removing the weed block circle. This picture makes it look more solidly black than it is.
I might wanna go looking for a more solid black lawn fabric and just buy it. I want UV stability and an easy process with a clean look (for DIY). This ain't it.
Originally Posted by 19bonestock88 View Post
I think it looks pretty nice... should give you “most” of the benefits of a smooth wheel cover without the pain of attachment
Do you mean the stripe or the whole wheel looks good. What think u of the stripe?
