Old 05-03-2018, 11:52 AM   #102 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
The upstream and the downstream sensors are both really easy. Upstream is on top of the exchaust manifold and downstream after the catalytic converter. You need a wrench and hands. The ratchet or wrench should be of the open type, like a crowfoot. Careful removing the clips for the harness, which are close to the sensor itself. The plastic gets brittle. You DEPRESS the tab to release the lock on the connector. You do not pry it loose. You have the manual?
westb87 (05-03-2018)
