Old 05-06-2018, 10:43 AM   #129 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I'll add that the power steering delete one one of the biggest bangs for the buck (free) and it is easy to test in a reversible way: just loosen and remove the power steering belt for a a few days. See how it feels. It will be a little stiffer than it could be because it will still have the PS fluid in the rack, but you will see what it is like. I remember thinking it was associated with a 1-3 MPG improvement, though your benefit may vary and will be nearly impossible to "prove."
EDIT: btw, your 04 Civic EX auto has taller cruising gearing than a 6th Gen Civic HX manual, just barely. And with taller wheel/tires you'll be approaching the freeway cruising RPMs of a fifth gen VX.
