Old 05-13-2018, 08:58 AM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Stubby79 View Post
Is the missing gasket material stuck to the head & block, or is it just gone?
It seemed mostly just to be gone. Not all areas were all that contaminated beyond a little discoloring. Around #1 & #2 there were deposits stuck to the surface of head and block that I interpreted as carbon and maybe gasket material. #3 & #4 were much cleaner, though cylinder top #4 was just as gummy as #1. I did the razor cleaning of the block mating surface, and though I did not want to dig too hard for fear of gouging some of what flaked-off the block must have been gasket material.
Originally Posted by Baltothewolf View Post
Probably blown out and gone. Have a similar failure on 2 different cylinders on my 4Runner. No coolant in the oil, but oil in the coolant and catastrophic failure occurred after about 1500 miles of driving it with them 'mildly' blown. (burning off minor coolant and changing coolant every 200mi to keep it from getting too contaminated).
That was nearly my exact situation. And checking frequently revealed it had suddenly gotten much worse in a couple hundred miles. Still was not nearly fully blown, btw. But unmistakably headed toward the death of the engine without intervention.
