Old 05-12-2018, 06:18 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
"Reading" 1998 Honda Civic head gasket failure
Almost done with head gasket replacement. Since I know I pulled the original 1998 Honda head gasket from the car because I have owned it since June 2001, I thought it would be fun to compare the old with the new OEM. Inthese photos, the new one is above the old. See all the missing black material on the old one? The #1 cylinder seemed to be the worst. On the head and on the block, the worst contamination was around #1 and also #2, though it was not quite as bad.
Top of the gaskets, #1 cylinder is on the right
Bottom of the gaskets, #1 cylinder is on the left
Oil was getting into coolant, coolant was contaminted with combustion gasses, and a little coolant and maybe oil was burning. But no coolant ever in the oil.
"Reading" it, I see the day I first brought my daughter home, thousands of commutes, trips all over the country, including through the Hopi and Navaho reservations... across country, & 260,000 miles of never fail machine greatness.
Engineering is amazing. Precision factory production is amazing.
ID:	24165   Click image for larger version
Old 05-13-2018, 03:07 AM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Is the missing gasket material stuck to the head & block, or is it just gone?
Old 05-13-2018, 03:13 AM   #3 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Probably blown out and gone. Have a similar failure on 2 different cylinders on my 4Runner. No coolant in the oil, but oil in the coolant and catastrophic failure occurred after about 1500 miles of driving it with them 'mildly' blown. (burning off minor coolant and changing coolant every 200mi to keep it from getting too contaminated).
Old 05-13-2018, 08:58 AM   #4 (permalink)
Cyborg ECU
It seemed mostly just to be gone. Not all areas were all that contaminated beyond a little discoloring. Around #1 & #2 there were deposits stuck to the surface of head and block that I interpreted as carbon and maybe gasket material. #3 & #4 were much cleaner, though cylinder top #4 was just as gummy as #1. I did the razor cleaning of the block mating surface, and though I did not want to dig too hard for fear of gouging some of what flaked-off the block must have been gasket material.
That was nearly my exact situation. And checking frequently revealed it had suddenly gotten much worse in a couple hundred miles. Still was not nearly fully blown, btw. But unmistakably headed toward the death of the engine without intervention.
Old 07-04-2018, 02:14 AM   #5 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.59 mpg (US)
One of my favorite parts of the country. LOVE the southwest.
Old 07-05-2018, 07:20 PM   #6 (permalink)
Cyborg ECU
Love New Mexico even more. The trip on this head gasket that featured The Hopi rez also visited the Taos Pueblo, an amazing thousand year housing complex in which Popé himself once lived. Fabulous to be there.
Old 07-05-2018, 07:31 PM   #7 (permalink)
Renaissance Man
Formula413's Avatar
The Pueblos were great too. First time I tried fry bread The tail end of the Rockies in northern NM and the Jemez Mountain Trail are spectacular.
Old 07-05-2018, 08:22 PM   #8 (permalink)
Cyborg ECU
I like to think that I lost a little head gasket meterial in that region as I passed through 12 years ago, and perhaps traces of it dripped out the tailpipe with water from the combustion exhaust... onto the desert roadway... (alongside lots of carbon unfortunately!)...
Old 07-09-2018, 01:26 AM   #9 (permalink)
Are Navajo tacos still Navajo tacos if they are made by gringos?
Old 07-09-2018, 09:33 AM   #10 (permalink)
Cyborg ECU
Yes (and no).
