Old 05-17-2018, 10:32 PM   #43 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Interesting. My Dasher's injectors will be laying on a bench soon, if not already. So what's the best container material? Copper or bronze? And what's the proportion of water to HCL?
I just have a very simple, cheap Walmart pot. Steel? The acid is very mild, a mix of citric and oxalic in the proportion to water described in post #1 of this thread. Took my daughter to an appointment tonight and so far, still 100%. I hope to not see the P0420 code again. And if I do,I will be more confident that it is the CAT and not a sensor. Given that the head gasket was failing, it is not surprising that I have some exhaust system troubles. The CAT prolly needs help, too.
freebeard (05-17-2018)
