Old 06-14-2018, 12:20 PM   #12 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Baltothewolf View Post
Be careful with that. The ex valves not being open long enough can significantly raise EGT's and cylinder tempuratures. I'm sure it's fine, I would just be conscious of it.
Yes, and there should be more heat transfer to the head as a result of longer duration of exhaust valve contact with the valve seat. But I kept it all ridiculously conservative by staying within specs and just pushing to the opposite ends of the limits. The idea is better emissions and FE because of a more complete burn and higher manifold air pressure. There is an article I linked in my mod thread (link below) if you wanna see more.
