Old 08-06-2018, 07:11 PM   #4 (permalink)
oil pan 4
In new Mexico the base rate is 7 or 8 cents per kwh with wind and coal power. Operating cost is a little under 2 cents per mile.
No motor oil changes or other ice related maintenance.
I believe the EPA standard claims that a gallon of gasoline is worth 35kwh. For me it's like having gasoline that's less than $2.50 a gallon. But the electric vehicle is around 2 to 4 times the efficiency of a gasoline ICE.
The leaf holds about 2/3 of a gallon worth of gas in the form of battery power but that will easily allow for around 70 miles of driving. No other normal gasoline vehicles will comfortably go 70 miles with 2/3 of a gallon of gas.
The car should go 80 to 100 miles but why chance it.
Ecky (08-07-2018)
