Old 08-07-2018, 12:17 PM   #11 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Perhaps copy the design of this U-Haul trailer but scale it down for your needs. https://www.uhaul.com/Trailers/4x8-C...ler-Rental/UV/
It is probably the best combination of ease of construction, aerodynamics and cargo capacity. The corner radius helps in crosswinds and overall aerodynamics.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
slowmover (08-11-2018)
