Old 08-11-2018, 06:01 PM   #108 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by 19bonestock88 View Post
Stock for my Saturn is 4x100, 12x1.5 lugs, 15x6”, 38-42mm offset and 57.1mm hub center bore...
The center bore being bigger on your car is a problem. They won't mount correctly. I could use your rims on my Civic, with a spacer, but you can't mount 56.1 center bore HX rims to a 57.1 hub safely. Bummer.
mpg_numbers_guy (08-11-2018)
