Thread: Wind turbines
Old 09-06-2018, 05:18 AM   #1 (permalink)
oil pan 4
Wind turbines
So what’s the carbon foot print of a wind turbine with 45 tons of rebar & 625 yards of concrete?
Its carbon footprint is massive – try 241.85 tons of CO2.
Here’s the breakdown of the CO2 numbers.
To create a 1,000 Kg of pig iron, you start with 1,800 Kg of iron ore, 900 Kg of coking coal 450 Kg of limestone. The blast furnace consumes 4,500 Kg of air. The temperature at the core of the blast furnace reaches nearly 1,600 degrees C (about 3,000 degrees F).
The pig iron is then transferred to the basic oxygen furnace to make steel.
1,350 Kg of CO2 is emitted per 1,000 Kg pig iron produced.
A further 1,460 Kg CO2 is emitted per 1,000 Kg of Steel produced so all up 2,810 Kg CO2 is emitted.
45 tons of rebar (steel) are required so that equals 126.45 tons of CO2 are emitted.
To create a 1,000 Kg of Portland cement, calcium carbonate (60%), silicon (20%), aluminium (10%), iron (10%) and very small amounts of other ingredients are heated in a large kiln to over 1,500 degrees C to convert the raw materials into clinker. The clinker is then interground with other ingredients to produce the final cement product. When cement is mixed with water, sand and gravel forms the rock-like mass know as concrete.
An average of 927 Kg of CO2 is emitted per 1,000 Kg of Portland cement. On average, concrete has 10% cement, with the balance being gravel (41%), sand (25%), water (18%) and air (6%). One cubic metre of concrete weighs approx. 2,400 Kg so approx. 240 Kg of CO2 is emitted for every cubic metre.
481m3 of concrete are required so that equals 115.4 tons of CO2 are emitted.
Extra stats about wind turbines you may not know about:
All this stands on a concrete base constructed from 45,000 Kg of reinforcing rebar which also contains over 481 cubic metres of concrete (that’s over 481,000 litres of concrete – about 20% of the volume of an Olympic swimming pool).
Each turbine blade is made of glass fibre reinforced plastics, (GRP), i.e. glass fibre reinforced polyester or epoxy and on average each turbine blade weighs around 7,000 Kg each.
Each turbine has three blades so there’s 21,000 Kgs of GRP and each blade can be as long as 50 metres.
Each and every wind turbine has a magnet made of a metal called neodymium. There are 2,500 Kg of it in each turbine.
The mining and refining of neodymium is so dirty and toxic, involving repeated boiling in acid, with radioactive thorium as a byproduct.
China is saving all their byproduct thorium. This is why they are developing thorium nuclear reactors.
That doesn't include mining for the steel and concrete raw and finished product transportation, all the electrical infrastructure needed to connect them to the grid.
I like wind power.
Just don't give it a free pass and pretend like it never produced any pollution.
Not so great.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
RustyLugNut (09-06-2018), sendler (09-14-2018)
