Old 11-21-2018, 07:55 AM   #111 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
You suspect because of a bright LED?
I don't think that indicates a bad cap. LEDs can be brighter or dimmer with slight differences in voltages.
I'd still test it all though. As I said, it's a good idea to charge them to the same voltage and let them sit a while and see if they discharge at similar rates.
I'll measure it this afternoon against the others, but they all started off at the same voltage and brightness, so it's getting out of balance. How much, I'll find out.
