Old 11-30-2018, 06:16 PM   #119 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Sweet! So you're running caps only, and no battery?
How did you get around the problem of the DC/DC converter shutting down?
The voltage drop is much smaller from starting the car with these, so presumably that's lowering the current.
I plan to run a battery in parallel, but with a resistor so it has no starting duties.
