Originally Posted by mpg_numbers_guy
Won't interrupting the signal cause the IMA light to turn on? And since this would be a modification of the original clutch mod, doesn't the clutch mod prevent regen, but still allow assist (which is why the 0% SOC spoof would be necessary)?
I'm not sure. A lot of the "integrated motor assist" really isn't all that integrated and you can change a lot of things without the ECU knowing or caring. Would really just need to test.
Right now I'm at loss to figure out how to remove the lights from the rear of the Insight to measure the sockets...with the Civic I could just pull some carpeting back and voila, the lights and sockets were right there. On the Insight I can't see how to access them unless I literally remove the bumper and the entire light housing..
The tail light housings have to be removed. They're held on by 3 bolt-screws (8mm / philips). One is behind the carpet, the other two are behind little black plastic covers which you can see standing from the rear of the car.
Old picture:
