Originally Posted by 19bonestock88
Noise emanates from the front of the car, and is same turning left and right as far as I can tell... just changes pitch/volume with speed... wife said it sounds like a plane taking off lol...
Maybe both your front wheel bearings are failing. There is a good test where you jack the car up and hold the suspension spring to detect vibrations are you hand turn the wheel, if I recall correctly. Look it up in youtube. I had this problem a couple years ago. Replaced the bearing unit myself. Not super hard but really hacky.
