Old 02-06-2019, 02:56 AM   #17 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
My Ecomodder stickers showed up! One set went without incident, the other had some of the adhesive paper tear and threaten to leave behind the paper, but I approached from another angle and it came off cleanly.
Looking good!
I just have to remember not to scrape this one off when de-icing.
Originally Posted by jkv357 View Post
Just run a diesel oil if motorcycle-specific oil is too expensive.
T6 does shear down, but you want a lower viscosity oil anyway. Shear doesn't cause engine damage. Low ZDDP levels cause damage. I don't run T6 in my SV because the shifting isn't as smooth after the oil shears. The cost of 3 quarts of oil is not a major concern for me.
As far as the clutch not slipping, maybe it will and maybe it won't, but it takes time for the Moly to build-up on the clutch plates and cause slipping.
Want 15 - 20% better highway mileage? Cruise closer to 65 than 75.
I was referring to shear as the ability of the oil to keep metal parts separated, not the decline in viscosity. Also, when I referenced 75 MPH above, that would be indicated, which is 10% optimistic. The tachometer is also optimistic, even more optimistic than if the speedo were dead on.(on a stock geared bike that is..)
Cruising speeds are not up to me, as I usually don't lead except for in the twisties, but we also aren't going 75 mph. Its usually around 65-70.
ID:	25518   Click image for larger version
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following 2 Users Say Thank You to Daschicken For This Useful Post:
Daox (02-15-2019), MetroMPG (02-06-2019)
