Old 03-10-2019, 06:04 PM   #189 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by 19bonestock88 View Post
So, while I’m going to be in there, is there anything else that should be done? The bearings are sealed, so no grease upgrades... anti-seize the slide pins, clean up all the brake hardware... anything I’m missing?
Check your steering linkage boots for cracking. You could also check the rotors for warpage and/or bleed the brake lines. But you should be able to feel any significant warpage in the brake pedal. And the brake bleed need can be checked by examining the reservoir.
