Old 05-09-2019, 02:53 AM   #251 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Currently working on sorting out the fuel system. I hadn't realized but the TSX motor has a returnless fuel system. The CVT Insight also has a returnless system (or at least, the return is in the tank) whereas the 5MT Insight has a return line from the fuel rail. Looks like I'm going to need an aftermarket fuel regulator and to re-plumb the lines.
You might want a larger fuel supply line anyway. I think it's only 6mm/0.25" on the Insight?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Ecky (05-09-2019)
