Old 05-21-2019, 08:22 PM   #254 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Still need to sort out:
-Have CEL for VTEC pressure
-My harness had no connector for rear O2 sensor
A/C wiring
-Coolant gauge - I moved the old sensor over, just needs a wire
-Shortening shifter cables so 6 and R clear
-Put speedo converter box in so I have working speedometer
-Cruise control wiring
-Alignment
As a side note, the transmission is 100% brand new inside, and it's a bit hard to shift. It has less than 2 miles on it, hoping everything went back together right and it just needs to wear in.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
Daox (05-21-2019), roosterk0031 (05-21-2019)
