Old 05-29-2019, 12:42 AM   #289 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by mpg_numbers_guy View Post
...but so much harder to be frugal when you see the results on the speedometer!
Will you be reusing the stock MPG gauges in the cluster?
If possible. I haven't yet looked into how it works. If it's a simple analog injector pulse length count, like an MPGuino, that's good. If it's a digital output from the original ECU, that's less good.
