Old 06-10-2019, 01:28 AM   #54 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
...I had tried to follow Old School Funk's method for avoiding adjusting the timing belt, but I just do not understand how to make it work.
I used his method too. The wire was more than vigorous enough. I used to longest curtain rod and lashed it down so it wouldn't move. I found that the belt in the sprocket were not as susceptible to getting misaligned as I expected they would be.
...You need to have the head machined and they need to move it from top dead center. How do you move it back without the camshaft sprocket, which is secured to the timing belt and a broom?
This was tricky for me. I spent a lot of time turning the cam and watching the lifters and figuring out where the correct start position was. Obviously it's really important that the crank pulley not get turned and that the Pistons are on the exact position they were in when you pulled the head off. You'll get it if you're patient careful.
What do you mean adjusting the top and bottom separately? I don't understand. And I don't recognize that tool, which isn't surprising cuz I'm not extremely experienced.
Hang in there!
I kept trying to work on my Civic, but I was useless.[/QUOTE]
