Old 07-06-2019, 03:05 PM   #240 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Something to take into consideration, noise ratings on fans are not standardized at all and you generally can't even make meaningful comparisons between fans of the same manufacturer. Fans make a certain amount of noise just moving air, even if there's zero motor or bearing noise, and 21dba is a completely unrealisticly low noise rating.
Also, larger fans moving the same amount of air overall will be moving that air much more slowly, over a larger area. A 92mm fan will feel very slow in comparison to a 40mm fan pushing the same air because it's much less concentrated. You'll still get the same air moved over the components though.
The fans I chose were Panasonic FBA09A12V, rated for 40cfm. They have bearings which can tolerate being mounted horizontally and are quiet and reliable, a close relative of the IMA fan which came in the Insight.
