Old 07-22-2019, 08:11 PM   #225 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Hopefully the hub is the same or larger. I think Toyota uses the same bolt pattern but their hubs are smaller than anyone else's.
True. Civic center bore is 56.1mm and these MINI wheels bolt right up. Seems the Miata has 54.1 center bore... needs hub centric rings to adapt the 56.1mm wheel)to the 54.1mm hub. Can be had cheap online (10 or 20 bucks for the set).
