Old 09-12-2019, 07:12 PM   #28 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by Bicycle Bob View Post
Thanks, but that is still not the right way to test a tire. You need a flat "road" surface. I'd use a bench model belt sander with a worn belt that produces the same friction as asphalt. The wheel rides in a frame with load weights on each side, below the belt to keep it balanced. A cage keeps the rig from going off the test area, and once it is up to speed, the operator adjusts the inclination to get the tire running in the middle. The inclination reading is the payoff.
The absolute readings may not be correct, but I don’t see why the relative readings would be incorrect.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
