Old 08-12-2019, 03:29 AM   #21 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Originally Posted by oldtamiyaphile View Post
I find it telling that (almost) no no other MPG car has gone that route. All the current day EV's have pretty wide tyres, so I wouldn't read too much into the i3's tyre spec.
Aerovironment had to constantly fight GM to keep them from putting wide tires on the EV-1 for styling reasons.
Unfortunately, there is no good data on belted tires in the public domain, but racing bicycles still win on narrow tires for pavement. Also unfortunately, after a century of everyone understanding the basic engineering behind rolling resistance being inversely proportional to diameter, which operates on steel wheels and ball bearings, Greenspeed published a major test of bicycle tires all based on using a small diameter roller instead of a flat road surface, completely masking the difference.
Once they lay the rubber on the road, narrow tires leave it there for support for longer than a wide tire at the same pressure. However, a belted tire does not have to distort and scrub to create a contact patch. It can have a lower sidewall, and that is important because the strength needed there is directly proportional to the radius that it bulges out with to take the pressure.
Old 08-12-2019, 08:41 AM   #22 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by Bicycle Bob View Post
...… Once they lay the rubber on the road, narrow tires leave it there for support for longer than a wide tire at the same pressure. ...…
My emphasis!
Part of the problem with testing bicycle tires is that narrow tires require MORE pressure to carry the same load than wide tires. The testing needs to be done at the same load carrying capacity - ergo, different pressures.
This problem is also present in passenger car tires, but to a much lesser extent because a difference of 10 mm width is almost nothing for a passenger car tire.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
The Following User Says Thank You to CapriRacer For This Useful Post:
Ecky (10-05-2019)
Old 08-14-2019, 07:02 AM   #23 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Racing bicycle tyres are getting wider and wider too. The 23mm tyres of a few years ago are nowhere to be seen and the pros ride as wide as 28mm. 18mm tyres are just history now.
Old 08-15-2019, 04:57 AM   #24 (permalink)
just joined..
Civic - '15 Honda Civic Tourer SR
ok, so i've FOUND a 5x114.3 wheel that's only 3.5" wide and made of aluminium - woohoo!
https://www.ebay.co.uk/itm/Genuine-L...0/262841685517
should fit right on to the honda, bit expensive but that's not the issue, i can't find any suitable tire to fit this. Only things i can find that are narrow enough are temporary use only
looked at i3 tyres but these are only 19" or 20". Also researched adapters to fit some i3 wheels but the increased height of the narrow tyre wont' fit in the arches..
Old 08-27-2019, 12:55 AM   #25 (permalink)
Decent-quality 13-inch tyres with a good efficiency rating are getting harder to find in my country, but recently my mother inquired me if it was worth replacing the 14-inch rims on her Toyota Etios for 13-inch ones to use tyres with taller sidewalls. I'd go that route if it wasn't for the harder availability of 13-inch tyres back here...
Old 09-12-2019, 03:34 PM   #26 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by CapriRacer View Post
My emphasis!
A recent test at bicyclerollingresistance addresses this issue. They did tests with multiple controls, the important one here being same tire drop(probably load capacity too). The rolling resistance turned out to be extremely close.
https://www.bicyclerollingresistance...000-comparison
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 09-12-2019, 03:50 PM   #27 (permalink)
Thanks, but that is still not the right way to test a tire. You need a flat "road" surface. I'd use a bench model belt sander with a worn belt that produces the same friction as asphalt. The wheel rides in a frame with load weights on each side, below the belt to keep it balanced. A cage keeps the rig from going off the test area, and once it is up to speed, the operator adjusts the inclination to get the tire running in the middle. The inclination reading is the payoff.
Old 09-12-2019, 07:12 PM   #28 (permalink)
Daschicken's Avatar
Motorcycle
Motorcycle
Motorcycle
The absolute readings may not be correct, but I don’t see why the relative readings would be incorrect.
Old 09-12-2019, 07:18 PM   #29 (permalink)
The deformation of wider vs longer contact patches will not be the same on a drum.
Old 10-05-2019, 07:24 PM   #30 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Going to a taller sidewall means you are less likely to dent your rims when you hit a pothole.
aerocivic.com
The Following 2 Users Say Thank You to basjoos For This Useful Post:
MeteorGray (07-10-2021), Xist (10-21-2019)
