Originally Posted by gasnmyveins
...the only tactile switched they show are single pole/single throw, 12vdc, 50ma 5mm high. Is that right ? They want $3.99 each. Is that good, or should I look for another source. Seems strange to pay $12 for 3 switches when the whole board kit can be had for $24.
The
iDuino is about $18, that's what I am using. If you order from them, you can get most everything else you need from them, including
$0.35 tactile switches that I am using in my setup. You can get more detailed info from the thread
iDuino MPGuino if you are interested.
