Originally Posted by Piotrsko
Probably the best solution is to drill a 1/16-1/8 dia drain hole through the intercooler pipe at the lowest point and block the lower grill air intake, which you did, then idle for a moment or two to push water out
VW's fixes have proven to not fix the water injestion issue. You're fortunate to not have bent the #3 rod.
You definitely DO NOT want to drill any holes in the charge air system, any boost leaks, even tiny ones can cause particulate filter failure.
