Old 11-19-2019, 09:36 AM   #61 (permalink)
I’ve had a couple of odd reactions from my TDI over the past month under heavy throttle. The car bogs almost like it is going into limp mode with a huge drop off in power. This lasts for a couple of seconds and then power comes back.
I found a procedure online to reset the drive by wire. Since the reset I haven’t had any weird power loss AND the throttle is linear. No more turbo lag off idle followed by a torque spike at 2,000 RPM. You might want to try it
To reset drive by wire
  1. Push the throttle all the way down and hold
  2. Turn on ignition but don’t crank the engine
  3. Continue holding down the throttle for 15 seconds
  4. Turn off ignition.
That just parks my wipers in the up position so I can remove them.
Old 11-19-2019, 10:23 AM   #62 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Weird. It doesn't do anything to my wipers.
On my 2014 parking the wipers in the service position requires:
  1. Ignition on
  2. Ignition off
  3. Press down on windshield wiper stalk.
EDIT: Here is a similar technique for a Touareg
The Following User Says Thank You to JSH For This Useful Post:
Xist (11-20-2019)
Old 11-20-2019, 09:32 AM   #63 (permalink)
Obviously big changes in software between years and models, possibly even assembly points. Mine is German made, and supposedly autobahn certified.
Old 11-21-2019, 09:34 PM   #64 (permalink)
Haven't been in here in quite a bit. Here's an update.
My JSW has been trouble free. mileage anywhere from 42-46. Better when it is hot.
I have put 31K on it since purchase in april.
Absolutely love it.
The only issue I have had was the intercooler icing problem. When you try to start, the engine turns over, then stops as if the battery died. It is because there was icing in the intercooler which melts after stopping. This water collects and is sucked into the intake at start up which hydro-locks it.
It can cause trouble, but didn't for me. After a few tries, it started, ran rough till it cleared it's throat in maybe 5 seconds. I have installed a lower grill pipe insulation block. Hopefully, this will prevent it from happening again.
Old 11-22-2019, 08:39 AM   #65 (permalink)
Absolutely love it.
The Jetta's, golf's, and beetle's actually have an updated intercooler available for that, if you are still within the new extended warranty it should be covered.
Old 11-22-2019, 09:44 AM   #66 (permalink)
Probably the best solution is to drill a 1/16-1/8 dia drain hole through the intercooler pipe at the lowest point and block the lower grill air intake, which you did, then idle for a moment or two to push water out
VW's fixes have proven to not fix the water injestion issue. You're fortunate to not have bent the #3 rod.
Old 11-22-2019, 10:14 AM   #67 (permalink)
You definitely DO NOT want to drill any holes in the charge air system, any boost leaks, even tiny ones can cause particulate filter failure.
Old 11-22-2019, 06:53 PM   #68 (permalink)
dang wish you told me that 5 years ago when I drilled mine. oh well have 5 more years on warranty and I think not having hydrolock is more important than a not very probable dpf failure.
BTW IT'S A DIESEL it runs lean ALL the time, kinda a diesel definition so it has no way to care about intake leaks since it doesn't have a throttle valve and has about a 50mm hole in the intake.
Fat Charlie (11-22-2019)
Old 11-22-2019, 08:30 PM   #69 (permalink)
Well I've replaced several dpf's over the years as a vw tech due to small boost leaks as a result of the overfueling they cause, but what do I know.
Old 11-23-2019, 12:05 PM   #70 (permalink)
JSH
AKA - Jason
JSH's Avatar
Wait just a minute. You drilled a hole between your MAF sensor and intake but you are blaming the dieselgate fix because your car doesn't run right?
