Old 12-10-2019, 05:50 PM   #34 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
never-before tried mod...
I've never made or tested side skirts before. But I was emboldened by GM's 'Vette patent:
Thread: GM aero patents (includes active side skirts for drag reduction)
The patent describes drag reduction in terms of shielding the rear tires (which, in the case of the Vette are probably 3 or 4 times wider than the Mirage's!).
The 14-15 Mirage didn't even get spats ahead of the rear tires. So hopefully this helps instead of hurting, because I won't be doing any A-B-A testing before April or May at the earliest!
I also like that the rocker skirt gives me options for integrating the rear wheel skirt -- could extend the wheel skirt lower and fair them together.
Also, while the middle of the Mirage underbody is relatively smooth (it has 2 OEM plastic aero panels), the rear underbody looks like a bit of a disaster. The side skirts should mean reduced flow there.
Next up: re-do the Kammback & air dam in coroplast.
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
Daox (12-10-2019), Gasoline Fumes (12-11-2019), mpg_numbers_guy (12-11-2019), Xist (12-10-2019)
