12-08-2019, 10:25 PM
#31 (permalink)
The passenger airbag can be switched of.
I wonder would this help in any way with removing the passenger seat.
Not sure what to do with the seat occupancy sensor. It is certainly very sensitive as I find that objects of no more than 1 kg sitting on the seat will trigger the seatbelt warnings.
12-09-2019, 08:38 PM
#32 (permalink)
Rat Racer
So don't mount it somewhere on the driver's seat frame where it won't be moved by someone sitting there.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
12-10-2019, 06:38 PM
#33 (permalink)
It's some kind of a weight sensor, in the foam part of the seat cushion. One of the Mirage forum members accidentally ruined his when shampooing the seat. It got a tad too damp.
12-10-2019, 06:50 PM
#34 (permalink)
never-before tried mod...
I've never made or tested side skirts before. But I was emboldened by GM's 'Vette patent:
Thread: GM aero patents (includes active side skirts for drag reduction)
The patent describes drag reduction in terms of shielding the rear tires (which, in the case of the Vette are probably 3 or 4 times wider than the Mirage's!).
The 14-15 Mirage didn't even get spats ahead of the rear tires. So hopefully this helps instead of hurting, because I won't be doing any A-B-A testing before April or May at the earliest!
I also like that the rocker skirt gives me options for integrating the rear wheel skirt -- could extend the wheel skirt lower and fair them together.
Also, while the middle of the Mirage underbody is relatively smooth (it has 2 OEM plastic aero panels), the rear underbody looks like a bit of a disaster. The side skirts should mean reduced flow there.
Next up: re-do the Kammback & air dam in coroplast.
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
12-10-2019, 08:08 PM
#35 (permalink)
Looks pretty good!
How did you attach them to the body?
12-11-2019, 09:12 PM
#36 (permalink)
Lookin' really good!
Maybe even mini boat tails behind the rear wheels, also integrated?
2006 New Formula Red Honda Insight MT, 282k: ( Build thread)
2013 Ember Black Volvo S60 automatic, 101k (Fiance's car):
12-11-2019, 10:12 PM
#37 (permalink)
Yeah, lots to do on this fuel-sucking pig!
I just drove it 80 km on wet/icy/slushy roads after a blizzard. Blasted more than a few snuds with the cardboard air dam -- I was surprised it was still intact when I got to my destination!
Computer said 58 mpg, which we know is probably ~5% optimistic. But that was into a quartering headwind, so not too bad.
12-11-2019, 10:28 PM
#38 (permalink)
Too many cars
Based on my lazy tuft testing, the side skirts seemed to prevent some air from going under the the Nut Wagon.
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
12-11-2019, 10:31 PM
#39 (permalink)
Too many cars
Ran out of black cable ties for the wheel covers?
12-11-2019, 10:35 PM
#40 (permalink)
Tuft testing is awesome.
White zip ties - I actually did that on purpose. I thought it might look interesting. Turns out I'm not crazy about it either.
