Do you know the approximate temp? For my "B18", IATs in the 90-110 range have been tested as most efficient (although it's hard to keep it under 120 in the summer). Perhaps the D-series engines of the same era share common ECU tendencies for intake air...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
