Old 05-04-2020, 04:55 PM   #23 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by GreenTDI View Post
The passenger wiper sits higher than the one on the driver's side, and I think it creates drag. Or not? See the picture below. So I tried to remove it today, but I failed due to corrosion, there is no movement at all after the bolt is removed. Is there a trick to get this out without any special material (and without demolishing the mechanism) ? I put some WD40 on it and will try it again tomorrow ...
Some guys take that one off. I did. It is impossible for people with our tools and techniques to know what effect it really has, but it is plausible that it disturbs airflow before it moves downstream. I took mine off and adjusted the driver one to sit slightly lower in the well while at rest.
GreenTDI (05-05-2020)
