Old 05-06-2020, 12:32 AM   #13 (permalink)
JulianEdgar
Originally Posted by M_a_t_t View Post
So what I am gathering is:
1.If you have an average wheel adding a wheel cover cover can likely improve aerodynamics
2. If you have an optimized wheel for aero adding wheel covers likely doesn't do anything.
3. Nothing in aerodynamics is guaranteed and you must test everything.
Yes, and add:
4. In some cars, full wheel covers can actually give negative results.
5. It's likely that the front and rear wheels should not be the same.
M_a_t_t (05-06-2020)
