Old 05-05-2020, 11:12 PM   #11 (permalink)
Originally Posted by M_a_t_t View Post
In one of your videos (Porsche on low drag wheel design) you say "Ventilation drag is...primarily through air passing through the openings in the wheels. Ventilation drag alone contributes up to 8% of total vehicle drag. Any difference in ventilation drag is going to be significant in terms of overall drag of the vehicle." (this isn't quite word for word, but very close) @~1:10
Then: ventilation drag is 50 percent tires and 50 percent wheels. This would suggest that 4% can be saved by putting full wheel covers on. This is double checked in the wheel graph you show later (@2:50) by a fully covered rim giving a -.015 Cd. On a car whose Cd is .30 this is a 5% decrease in drag.
In the qoute above you say you don't think it makes much of a difference. It sounds you are contradicting yourself. Maybe what you mean by "much of a difference" is different than my version? I know if Porsche went through the effort to find these results and I would assume that Honda did for the insight then full wheel covers would be worth their effort on our own cars (rather than buying a new set of rims).
I actually said "moving from a good standard wheel to one with a full cover I doubt does anything at all". I stand by that. Obviously, a really crappy wheel can be improved on, but here you see people putting full covers on Gen 1 Honda Insight wheels, etc.
I would like to thank you for the compliment in wheels (again in the video) as I've put insight wheels on my mercury. What tires are you running on yours? Some have said some of the newer FE tires have worked better than the original spec potenza re92's.
I use Kumho Ecowing.
On longitudinal drag: If you put wheel skirts (or spats) on the outside and enclosed the wheel well as best as you could while still allowing the suspension to articulate do you think this would mitigate most of the longitudinal drag and ventilation drag? Possibly worth 6 or 7% in the case you were making in the video?
I don't know - I've not seen any engineering data on the magnitude of drag reduction from skirts. I also imagine it would vary from car to car, and especially from wheel design to wheel design.
Edit: I just watched your video on "deceptive rules of thumb in car aerodynamics" and could see a point to be made that not every car will see these results. None of the evidence I've seen has said you would get worse Cd by adding them though so they should always show some benefit. Correct?
No, not correct. Two such examples are covered in my book.
Old 05-06-2020, 12:06 AM   #12 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I know what you said I quoted it in my post and put it in bold...
So what I am gathering is:
1.If you have an average wheel adding a wheel cover cover can likely improve aerodynamics
Obviously, a really crappy wheel can be improved on.
and
2. If you have an optimized wheel for aero adding wheel covers likely doesn't do anything.
and the second part of the graph above reflects this because most of the area of the 1st gen insight wheels are covered so the reflected change in drag would be smaller and therefore marginal at best.
3. Nothing in aerodynamics is guaranteed and you must test everything.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 05-06-2020, 12:32 AM   #13 (permalink)
Yes, and add:
4. In some cars, full wheel covers can actually give negative results.
5. It's likely that the front and rear wheels should not be the same.
M_a_t_t (05-06-2020)
Old 05-06-2020, 02:41 AM   #14 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I was looking through some of your videos and found this:
Why didn't you link to it earlier? It answered pretty much every question I've asked.
1995 Mercury Tracer
Old 05-06-2020, 03:15 AM   #15 (permalink)
Um, read my book and then you'll know - and not have to stumble across my YouTube videos?
Plus, lots more detail in the book - the tech papers are cited, etc. One paragraph in my book is a whole YouTube video.
Old 05-06-2020, 03:20 AM   #16 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I haven't been to work in a few weeks due to COVID-19. So I won't buy your book(s) right now. Hopefully in the future.
I've heard you say that before, I think it was in your suggested books video
It still seems easier to the alternative of us replying back and forth.
1995 Mercury Tracer
Old 05-06-2020, 01:43 PM   #17 (permalink)
I have Youtube trained up to put your videos on [my] front page.
But better than stumbling, is https://www.youtube.com/channel/UCK9...uiCjxcQ/videos. I count 219 videos in the last year. Most popular is The truth about vortex generators on cars.
Two wrongs don't make a right, but three lefts do.
