Old 05-20-2020, 10:42 AM   #61 (permalink)
aerohead
should I ?
Originally Posted by COcyclist View Post
I want to see this version tested.
I'd just follow Ford's contour,as if you were completing it with a french curve. I'd also just drop the side aprons (capping plates) down the the bottom of the glass, enclosing as much side area as you can. You'll have a little more blind-spot, so use your side mirrors frequently to know your driving environment at all times.
bobo333 (05-20-2020)
