Originally Posted by jakobnev
I added an extra piston:
Nice addition. More power!
As for me, I have my throttle limiter good to go. It's easily installed and removed and it keeps a constant throttle losition perfectly and safely every time.
Less fun, P0135 and P0141 DTC codes showed up (heater circuits on both O2 sensors). Following the "test, don't guess" principle, I ran resistance, power, and ground tests with my multimeter. The O2 sensors are fine. The wiring harness supplies power but insufficient ground. To the wiring diagram!
