Old 09-15-2020, 11:56 AM   #69 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Since all SAC (or whoever they are nowadays) primary runway faced pretty much due north, the B52 gear skews up to 6 degrees which is why they are on centerline, the wingtips have retracting swivel gear. G and H models are essentially upgraded rebuilt D models.
Not sure because I can't find my whiz-wheel, but that skew is good for about 50 mph crosswind
It was predicated on the centerline main gear and relatively light outrigger gear. *That* was predicated by the high mounted wing position, big mains would be huge and heavy outboard on those wings that are so high in the air.
Note that huge airliners have substantial outboard main gear that can take the abuse of a significantly dropped wing to keep tracking centerline in a forward slip.
The B-52's little outrigger gear would simply break off if you did that to make that transition from crabbing to cross-controlled forward slip to landing. Heck, the wing would break if it did not!
<< Is a pilot
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
