09-12-2020, 12:10 PM
#61 (permalink)
Rat Racer
Those ones actually pivot. I don't know if it was on all B-52s, and I don't think it's on any other planes.
I've sat through a few crosswind landings and they're pretty unsettling. In something the size of a B-52 (and with the load it generally carries), playing with the landing gear makes a lot of sense.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
09-12-2020, 02:24 PM
#62 (permalink)
If that handle shows up and freebeard disappears, it was me.
09-12-2020, 03:02 PM
#63 (permalink)
Rat Racer
If it's texty mcswervalot, I'll believe it.
09-12-2020, 03:19 PM
#64 (permalink)
You're saying I'm not the shifty type?
09-12-2020, 04:13 PM
#65 (permalink)
Rat Racer
Just that you seem to prefer to keep a low profile.
09-14-2020, 10:44 AM
#66 (permalink)
Originally Posted by redpoint5
Do the wheels pivot to face direction of travel? I always thought they just scrubbed upon touchdown.
Since all SAC (or whoever they are nowadays) primary runway faced pretty much due north, the B52 gear skews up to 6 degrees which is why they are on centerline, the wingtips have retracting swivel gear. G and H models are essentially upgraded rebuilt D models.
Not sure because I can't find my whiz-wheel, but that skew is good for about 50 mph crosswind
09-15-2020, 10:30 AM
#67 (permalink)
I'm willing to learn something here but I'm going to need some guidance.
Is the lift of the Dream created by the attached airflow over the top of the profile or because the design of the underside creates more pressure on the underside than is created on the top (underside pressure >topside pressure. Lift created by a specific design.) or us the lift created by the basic shape resembling an airfoil and adds as such (Bernoulii ?) because it is positioned high enough off the road that it acts as a "wing" (not a specific underside design to create lift, but placement of a basic design in relation to the road to create lift)
If nice guys finish last, are you willing to pay the price to finish first ?
The Following User Says Thank You to hat_man For This Useful Post:
09-15-2020, 10:42 AM
#68 (permalink)
The airflow is not attached, and the lift is Bernoulli caused. Others will find nits and pick them, but this is simple and succinct
09-15-2020, 11:56 AM
#69 (permalink)
It was predicated on the centerline main gear and relatively light outrigger gear. *That* was predicated by the high mounted wing position, big mains would be huge and heavy outboard on those wings that are so high in the air.
Note that huge airliners have substantial outboard main gear that can take the abuse of a significantly dropped wing to keep tracking centerline in a forward slip.
The B-52's little outrigger gear would simply break off if you did that to make that transition from crabbing to cross-controlled forward slip to landing. Heck, the wing would break if it did not!
<< Is a pilot
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
09-15-2020, 01:19 PM
#70 (permalink)
I thought unattached airflow (flow separation?) was more turbulent and caused more drag. If the Dream is low drag then wouldn't it have more attached air and less turbulent air moving around the body?
