Old 12-23-2020, 03:16 PM   #57 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Do they cut rebar at the Home Depot? Could you get them to cut the ends off at an angle? Even a 45 would be helpful for pounding. You could also do that with a hack saw. Are you pounding them in to the ground at an angle? They should go in at maybe ten to fifteen degrees away from the shed.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
