Old 09-29-2008, 04:42 PM   #20 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
If you have an ammeter in your car you can estimate your battery life by the capacity rating. Example is a Trojan 12v 27tmx with a 175 minute capacity. This battery can provide 25 amps of power for 175 minutes in ideal conditions and down to 100% discharge. You should really only discharge to 50% (12.06V) max for deep cycle batteries. So half that figure is about an hour and a half.
Watts / volts = amps. Amps x volts = watts.
Low beams are typically 55 W each X2 = 105 / 12 = 8.75 amps. The heater fan depends on the setting and the vehicle. Many lights can be replaced with
LEDs which only use a fraction of the power.
From another forum...Don't know the car model but would be good enough to estimate.
I tested at both voltage settings of the alt, where 14.4 is typical alt voltage, and 12.7 is similar to a fully charged battery. The idle current is subtracted out of the other settings.
Idle: 128w @ 14.4v, 89w @ 12.7v
Rev up to 3500 rpm: +35w, (not tested)
Heater fan setting 1: 55w, 38w
Setting 2: 98, 67
Setting 3: 141, 99
Setting 4: 189, 135
Marker lights: 95, 71
Full lights: 240, 179
A/C (heater fan subtracted, but including condenser fan): 163, 114
Defroster: 104, 77
Wipers 1: 48, 38
Wipers 2: 76, 64
Radiator fan: 144, 83
The more current you draw the less capacity your battery can provide.
Your homework
Welcome to Battery University
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Last edited by orange4boy; 09-29-2008 at 04:48 PM.. Reason: clarity = added formula
