Debuting in the refreshed-for-2021 F-150, the PowerBoost hybrid pairs Ford's twin-turbocharged 3.5-liter V-6 with a 47-hp electric motor, making this the highest-output powertrain in the current F-150 lineup. The motor is sandwiched between the engine and the stand*ard 10-speed automatic, while a 1.5-kWh lithium-ion battery tucks under the bed. The battery may seem a bit small for a vehicle of this size, but Ford chose it because it's easy to package and less costly than larger packs, and its weight won't considerably impact the all-important towing and payload capacities. Combined output for this powertrain is a stout 430 horses and 570 pound-feet of torque—gains of 30 ponies and 70 pound-feet versus the updated nonhybrid EcoBoost 3.5-liter.
At 5794 pounds, our four-wheel-drive Lariat weighed 200 pounds more than the last F-150 Limited we reviewed, yet its solid 5.4-second run to 60 mph means it's fleeter than most half-ton trucks... the max payload and towing capacities for the hybrid are impressive, at 2120 and 12,700 pounds, respectively.
The motor isn't designed to provide meaningful acceleration on its own, but it does allow for short periods of electric cruising at low speeds. Transitions from gas to electric power are almost imperceptible, as is the changeover from regenerative to friction braking. The hybrid scores 24 mpg on the EPA's combined cycle, 4 mpg more than a regular EcoBoost 3.5 F-150 manages.
The hybrid option can be had on any F-150 crew cab for a somewhat reasonable $2500 to $4495, depending on the trim level. That equates to base prices of $42,840 to $77,845.
https://www.caranddriver.com/reviews...y-the-numbers/
Getting closer to what I envision, but I want to see something like a series hybrid with a small 4 cylinder engine and no transmission.
