Old 06-02-2021, 11:32 AM   #16 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Getting good flow on the bottom of your boattail may be difficult in the real world. If you ever have to drive up or down a ramp the back end of the boattail can drag on the ground.
https://en.wikipedia.org/wiki/Trailer_tail
These are sometimes used on semi truck (tractor-trailers) trailers here in the U.S. It is compromise toward utility over aerodynamic optimization.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (06-09-2021)
