A few more thoughts I should have mentioned...
I want this to be a template for an eventual metal skid plate. With that being said any "frame" work I do to support the coroplast I would prefer would be setup to accept the plate without modifications.
I did test run this guy on a windy, hilly backroad approaching 60 MPH and there was no discernible movement. I was listening with the window down for anything. Also, the bolt in the previous post is well into the nut with no signs of movement.
Even though it's not secured, the middle of the pan does have a resting support so it doesn't flop as it rests against the radiator lower support.
I work for an electrical contractor, I wonder if I can utilize some strut in some way.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
