Old 06-07-2021, 10:30 AM   #16 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
^ X2 (You can get really bad fumes even if you grind or sand. Do this in a really well ventilated area)
"Speed Nuts" work for attaching to the edge of the airdam etc. It slides over one edge like a paperclip with a nut on the back, pre-drill a small hole and the screw draws it tighter.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (06-09-2021)
