Got the front passenger side fully assembled, finally. I still need to bleed the brakes so the wheel will come back off, but everything is torqued down. While I had it off the ground I changed the transmission fluid and engine oil (Mobile 1 0w30 AFE, Honda MTF). I also had to grind down a ridge on the axles I bought because they were rubbing the knuckles and causing resistance when I torqued down the axle nut.
Confirmed the Insight brakes and rotors do fit perfectly.
Also the DMV finally cashed my check for plates and registration.
