1997 Civic hatchback with 142,000 miles for $650
Honda Civic hatchback. 1997. Mostly sound. It is old. It has been sitting for a couple of years. She ran well when last used. Shifted fine, brakes, etc. The ignition switch is not working properly and I just remote start it, which it starts up just fine. The battery went bad. I have a battery that doesn't fit, but I use it to start it. The seats had seat covers the entire time, so should be nice underneath if the material is sound. The headliner is falling apart. The paint has some big spots that it just flaked off (paint is bad). There is a tiny bit of superficial rust, but zero big rust or any damaging rust. All the glass is intact. The tires are decent. It could be driven, but I would personally tow it and give it a once over before you take off on the streets with it. I will be upfront with all. If you have any questions, just ask.
https://phoenix.craigslist.org/nph/c...335850213.html
