Old 02-26-2022, 06:56 PM   #1 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Can't keep Aerocivic!
At least not easily. So, I'm choosing again to pass it along to the next lucky owner. It's had a full mechanical tune-up, brand new tires, "new" old wheels, all the the suspension is brand new, new CV axles, new brakes, new bearings, new steering wheel, new gauge cluster with tachometer, new battery, and I started reupholstering the interior. It has side- and rear-view cameras. It will also come with an MPGuino color touch. It's basically ready for the road.
To see that it makes its way to a good home, I'm offering to deliver it to its new home. Local pick-up in Michigan is preferable. I'd also prefer whoever has it next doesn't use it as a winter beater - these old Hondas don't hold up to salt well.
Mechanically, what I believe it still needs:
-The driver front frame rail is slightly down and in, making the hood not line up well. It still latches fine. I had planned to put the car on a straightener. I expect this to be an optional few hundred dollars.
ID:	31739   Click image for larger version
ID:	31740   Click image for larger version
The Following 2 Users Say Thank You to Ecky For This Useful Post:
aerohead (02-28-2022), Gasoline Fumes (02-28-2022)
