Old 05-09-2022, 03:48 AM   #38 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
- There is optimal injection timing for best efficiency
- There is optimal boost level for certain injection level at certain RPM
- There is optimal cam (or cams) timing
You need to find those out by doing sweep runs and tests.
In general the EGR is not boosting efficiency so its not in use. I should still try to test will it help at low rpm and injection levels as there is a reason why it migth help to boost little bit efficiency.
In my own ecu programs is a AFR limitation to set 19 meaning, I will never go richer than that. There is no need. At higher rpms AFR can go over 45 if you want to get best efficiency.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
