Old 09-30-2022, 02:20 AM   #1 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Efficient alignment
I could use some opinions on alignment numbers.
I haven't taken the MX-5 in for an alignment yet. It tracks straight, but it's a fair bet that the previous owner had a fairly aggressive, perhaps even autocross-oriented alignment on the car, based on how much front camber there is.
Factory specs, per wheel:
Front:
Caster: 5.5° to 7.5°
Camber: -1.7° to 0.3°
Toe: -1/16" to 1/8" (ideally 1/32" toe in)
Rear:
Camber: -2.7° to -0.7°
Toe: -1/32" to 5/32" (ideally 1/32" toe in)
Flyin' Miata recommends the following for aggressively driven street cars:
Front:
Caster: 8.0°
Camber: -1.8°
Toe in: 1/32" per side
Rear:
Camber: -1.8°
I take corners at rather high speeds, so I'm looking for a reasonable compromise. I'm thinking of dialing the caster back just a bit, perhaps 6°, and setting camber to something like -1.5°. What I'm not certain about is toe. I can see a reason for having just a bit of rear toe in, but since the car is propelled by the rear wheels and it ought to have a tendency to toe-in anyway under power. What would be the purpose of slight front toe in? Thoughts on zero toe, front and back?
