Old 12-10-2022, 09:27 PM   #4 (permalink)
oil pan 4
Definitely has the wrong jet in the carb, it stinks from like 50 feet away and sputters when I go to wide open throttle.
I removed the WAI to try and give it CAI, didn't help much.
It was 45 degrees f out, in degrees C that's kind of chilly. The hydraulics got quite warm, hot enough so I didn't want to leave my hand on the cylinder, so it will probably need a cooler.
I actually did read the manual.
It has a 14gpm pump, 4.375 bore runs a max of 3,750psi.
A remote throttle would be nice.
